Place your Arlo Pro 3 Floodlight Camera 8-10 feet (2.5-3 meters) off the ground, angled toward the ground, and within range of your WiFi router. Each home system setup is unique, so use these guidelines as general best practices.
The following image shows the floodlight’s beam spread within the camera’s field of view (FOV) only. This is not a representation of the floodlight’s full beam spread, which exceeds the camera’s vertical field of view.
When mounting your Arlo Pro 3 Floodlight Camera:
When placing your Arlo Pro 3 Floodlight Camera:
The following materials reduce WiFi signal strength the most:
If you connect your Arlo Pro 3 Floodlight Camera to an Arlo SmartHub or base station, visit How do I position my Arlo wire-free camera?.
