How do I find the regulatory e-label for my Arlo product?
Some Arlo products have a regulatory e-label that you can access in the Arlo app or web portal. This is because a printed regulatory label does not fit all of the regulatory information on the Arlo product label.
To find the regulatory e-label for your Arlo product:
  1. Launch the Arlo app or log in to my.arlo.com.
  2. From the Devices screen, open the Device Settings page for your Arlo product.
    1. On iOS and web browser, tap the Settings icon next to your Arlo device.
    2. On Android, tap the menu icon next to your Arlo device, then tap Device Settings.
  3. Tap or click Device Info > Regulatory
Note: If the Arlo app does not show a Regulatory sub-menu for your Arlo product, then the product does not have a regulatory e-label, and you can find all regulatory information on the physical label located either at the base, inside the battery compartment, or near the power input port of the Arlo product.
For additional compliance information on Arlo products, visit https://www.arlo.com/en-us/about/regulatory/.
