Arlo wire-free cameras use rechargeable batteries and can go wherever you need them. The original Arlo Wire-Free camera (VMC3030) uses non-rechargeable for more information, visit Safety Rules for Arlo Non-Rechargeable Batteries.
All batteries can explode, catch fire, and cause burns if disassembled, punctured, cut, crushed, short-circuited, incinerated, or exposed to water, fire or high temperatures, so you need to handle them with care.
To use Arlo rechargeable batteries safely:
Your Arlo Pro Wire-free or Arlo Go HD Security Camera has been specifically designed for use only with Arlo Rechargeable Batteries. Therefore, only use Arlo Rechargeable Batteries with Arlo Pro Wire-free and Arlo Go Cameras.
TO THE EXTENT PERMISSIBLE BY APPLICABLE LAW, ARLO DISCLAIMS ALL LIABILITY WHATSOEVER RELATED TO THE USAGE OF ANY BATTERY OTHER THAN ARLO PRO RECHARGEABLE BATTERIES IN YOUR ARLO PRO WIRE-FREE HD SECURITY CAMERAS OR ANY BATTERY OTHER THAN ARLO GO RECHARGEABLE BATTERIES IN YOUR ARLO GO HD SECURITY CAMERAS, INCLUDING WITHOUT LIMITATION, FIRE, DAMAGE TO PROPERTY, BODILY INJURY, AND/OR DEATH. YOU ASSUME ANY AND ALL RISKS ASSOCIATED WITH THE USAGE OF ANY BATTERY OTHER THAN ARLO PRO RECHARGEABLE BATTERIES IN ARLO PRO WIRE-FREE HD SECURITY CAMERAS, INCLUDING WITHOUT LIMITATION, FIRE, DAMAGE TO PROPERTY, BODILY INJURY, AND/OR DEATH. YOU ASSUME ANY AND ALL RISKS ASSOCIATED WITH THE USAGE OF ANY BATTERY OTHER THAN ARLO GO RECHARGEABLE BATTERIES IN ARLO GO HD SECURITY CAMERAS, INCLUDING WITHOUT LIMITATION, FIRE, DAMAGE TO PROPERTY, BODILY INJURY, AND/OR DEATH.
TO THE EXTENT PERMISSIBLE BY APPLICABLE LAW, FAILURE TO FOLLOW THESE WARNINGS AND/OR DIRECTIONS COULD RESULT IN DAMAGE TO YOUR ARLO PRO OR ARLO GO CAMERA THAT WILL NOT BE COVERED BY ARLO'S WARRANTY.
ALWAYS REMEMBER that poor quality or mishandled batteries can damage your cameras, cause a fire, or result in personal injury.
ARLO is not responsible for any failure to follow these battery usage guidelines.
