What is flicker adjustment on my Arlo device?
If you see flickering or black bands in the video footage from your Arlo device, you can try changing the flicker adjustment settings in the Arlo app.
The flicker effect occurs when a nearby light’s frequency is close to the same, but not the exact same, frequency as your Arlo device. To eliminate this effect, change your device’s frequency to the same frequency of the light that is causing the flickering.
To change the flicker adjustment setting:
  1. Launch the Arlo app or log in to my.arlo.com.
  2. Tap or click Settings > My Devices.
  3. Select an Arlo camera or video doorbell.
  4. Tap or click Flicker Adjustment.
  5. Select a Flicker Adjustment setting:
    • Auto. Tap or click for the flicker adjustment setting to be determined by your location.
    • 60 Hz. Tap or click if the nearby light’s frequency is 60 Hz.
      Note: A frequency of 60 Hz is standard in North America.
    • 50 Hz. Tap or click if the nearby light’s frequency is 50 Hz.
      Note: A frequency of 50 Hz is standard outside North America.
  6. If the flickering persists, try changing the flicker adjustment setting to a different option, or move the light away from your Arlo camera.
