My Arlo Security Light is set for 5 minutes but turns off after 10 seconds; what do I do?
Your Arlo Security Light has different duration settings for manual operation and for motion triggering:
  • Manual operation. Five minutes is the default amount of time that the light stays on when you tap the ON switch in the Arlo app. To change this setting, tap the gear icon beside your Arlo Security Light in the Devices screen and change your duration setting.
  • Motion triggering. When you use a mode that triggers your light to activate based on motion, the mode’s rules control how long the light stays on. The default duration in Armed mode is 10 seconds. To change this duration setting, see the following procedure.
Note: The default duration is short to preserve your light’s battery life. If you increase the light’s duration, you must charge your Arlo Security Light’s battery more frequently.
To change how long your Arlo Security Light stays on when it detects motion:
  1. Launch the Arlo app or log in to your Arlo account at my.arlo.com.
    The Devices page displays.
  2. Tap or click Mode.
  3. Tap or click the bridge that is connected to the light that you want to change motion sensitivity for.
    The Mode page displays.
  4. Tap the pencil icon or click Edit next to the mode that you want to edit.
    The Edit Rule page displays.
  5. Tap or click Edit next to the rule that you want to edit.
    The Edit page displays.
  6. Tap the pencil icon or click Edit next to Turn on Light.
  7. Under How long do you want the light on with motion?, move the slider to increase or decrease the light duration.
  8. Tap or click Back.
  9. Tap or click Save.
    Your settings are saved.
Note: You can also change beam width, flash, color, and brightness independently for both manual operation and motion triggering. To adjust these settings, follow the same steps listed above under Manual Operation and To change how long your Arlo Security Light stays on when it detects motion.
