How do I charge the battery that came with my Arlo Security Light system?
Use the USB cable and the indoor AC power adapter that came with your Arlo Security Light to charge the battery.
To charge the battery:
  1. If you’re using your Arlo Security Light outdoors, move it indoors while you charge the battery using the indoor AC power adapter.
  2. Connect the USB cable to your Arlo Security Light and to the AC power adapter.
    An image of an Arlo Security Light being plugged into the USB charging cord, which is plugged into the AC adapter, which is plugged into an indoor wall socket
  3. Plug the AC power adapter into an indoor wall socket.
    The battery begins to charge. The battery icon in the Arlo app Devices screen changes to indicate that the Arlo Security Light is charging.
