How do I change the motion sensitivity for my Arlo Security Light?
To change the sensitivity level for a light:
Launch the Arlo app or log in to your Arlo account at my.arlo.com. The Devices page displays.
Tap or click Mode.
Tap or click the bridge that is connected to the light for which you want to change motion sensitivity. The Mode page displays.
Tap the pencil icon or click Editnext to the mode. The Edit Rule page displays.
Tap or click Editnext to the rule that you want to edit. The Edit page displays.
Under If the following, tap or click Editnext to Motion is detected. The Motion detection settings page displays.
Move the slider to adjust the sensitivity level for motion detection for this light. If you used a mobile device to specify the settings, your settings are saved.
If you used a browser to specify the settings, click Save. Your settings are saved.
