How do I create an Amazon Alexa Routine for my Arlo Audio Doorbell?
You can create an Alexa Routine to trigger a smart home device when your Arlo Audio Doorbell is pressed.
To create an Alexa Routine for your Arlo Audio Doorbell, you must have the following:
  • Arlo Audio Doorbell
  • Amazon Alexa App
  • Alex enabled device (Echo, Fire TV, Fire Stick, etc.)
Before you can create an Alexa Routine for your Arlo Audio Doorbell, you must enable the Arlo Alexa Skill. For more information, visit How can I use Amazon devices with my Arlo cameras?.
To create an Alexa Routine with your Arlo Audio Doorbell:
  1. Launch the Amazon Alexa app.
  2. Tap the menu icon in the upper-left corner.
  3. Tap Routines.
  4. Tap the plus (+) icon in the upper-right corner.
  5. Tap When this happens > Device.
  6. Select your Arlo Audio Doorbell.
  7. Tap Add action under the Doorbell is pressed section.
  8. Select an action for Alexa to trigger.
