Follow these instructions if your Arlo camera is currently set up and connected to a VMB5000, VMB4540, VMB4500, or VMB4000 SmartHub or base station, and you want to connect the camera or doorbell directly to your 2.4 GHz WiFi network.
If your Arlo camera is not already set up, review the instructions on the in-package quick start guide.
Before you begin:
To connect your Arlo camera to your 2.4GHz WiFi Router:
To switch your Arlo camera from an Arlo SmartHub or base station connection to a direct-to-WiFi connection, you must remove the Arlo camera from your account and re-onboard it. Exact steps are provided below.
