To view your battery level:
Camera battery levels are accurate as long as the camera is close to room temperature (65-75°F, 18-24°C). Temperature variations can affect the accuracy of the displayed battery level.
The battery level is less accurate under the following conditions:
You receive a low battery notification when batteries have 15% of their charge remaining.
The following table shows how much charge is left based on the battery icon shown in your Devices feed.
Note: If your camera or base station is offline, the battery icon is hidden.
If your battery-powered camera is plugged in, the following icons display instead:
If you see the charging disabled icon, check for the following conditions:
