How do I set up my Arlo Security Light system?
To set up your Arlo Security Light system:
- If you are new to Arlo, download the latest version of the Arlo app from the Apple App Store or Google Play.
If you already use the Arlo app, update to the latest app version. - Launch the Arlo app from your smartphone or tablet.
- Create an Arlo account or log in.
If you did not set up an Arlo account yet, tap New to Arlo?.
If you already have an Arlo account, log in. - Tap Add Device and then tap Arlo Security Lights in the product list.
- Follow the onscreen instructions to add the Arlo Bridge and each Arlo Security Light.
For help troubleshooting setup problems, see the following knowledge base articles:
- I’m not able to set up the Arlo Bridge that came with my Arlo Light Security system; what do I do?
- I’m not able to set up my Arlo Security Light; what do I do?
- My Arlo Security Light's LEDs are not blinking blue when I press the Sync button; what do I do?
- When I scan the QR code that’s on the label of my Arlo Bridge, my Arlo app cannot read it; what do I do?
For more information about getting started with your Arlo Security Light system, see the following knowledge base articles:
