How do I set up my Arlo Go 2 Camera?
Last updated: 08.01.2025
Arlo Go 2 gives you the flexibility of using 2.4 GHz Wi-Fi or LTE for connectivity. You can also use LTE as a backup in case your Wi-Fi internet connection is interrupted.
Note: When using both 2.4 GHz Wi-Fi and LTE mode, Wi-Fi will always be the primary mode of connection.
Arlo Go 2 works with the same Arlo Secure App as all other Arlo cameras and devices. However, to connect your Go 2 camera to the mobile network, an activated SIM card with a mobile data plan must be inserted into the camera.
Note: We recommend that you charge the battery before mounting your camera. Your camera LED indicator light will blink amber if your battery needs charging. The indoor charging cable that came with your camera works with most power adapters.
- For more information, visit: How do I insert the battery in my Arlo Go 2 camera?
Need Help?
If you need help installing your new Arlo device, you can reach Arlo Support via the Need Help? button in the Arlo Secure App or on my.arlo.com.
- You may also join the Arlo Community where you can seek advice and solutions from experts and other Arlo customers.
To set up your Arlo Go 2 camera using LTE only:
- Launch the Arlo Secure App.
- Tap Devices.
Note: Make sure the correct Location where you want to add the device is selected. For more information, visit: How do I switch my Location in the Arlo Secure App? - Tap
- Tap Cameras.
- Tap Go 2.
- Tap Continue.
- Follow the instructions for installing your SIM card as shown on the Arlo Secure App and tap Continue.
For more information, visit: How do I install a SIM card in my Arlo Go 2 Camera?
The LED in front of your camera should blink blue. If the LED is not blinking blue, press the Sync button on the inside of your camera. - Tap Continue.
- Hold the QR code in the Arlo Secure App, 4 to 6 inches in front of your camera.
You should hear a chime from your Arlo device. If you didn't hear a chime, visit: My Arlo camera will not scan the QR code during setup - Tap Continue.
- Name your Arlo camera and tap Continue.
- Position your Arlo camera and tap Continue.
- Tap Finish.
To set up your Arlo Go 2 camera with Wi-Fi:
Note: Before setting up your Arlo Go 2, make sure that your mobile device is connected to a Wi-Fi network. For more information, visit: How do I connect my mobile device to a 2.4 GHz Wi-Fi network to set up my Arlo camera?
- Tap Devices.
- Tap Cameras.
- Tap Go 2.
- Tap Set Up with Wi-Fi.
- Follow the instructions for installing your SIM card as shown in the Arlo Secure App and tap Continue.
Note: You may skip this step if you are not using a SIM card.
- Verify your mobile device is connected to a 2.4 GHz Wi-Fi network and tap Continue.
- Enter your Wi-Fi credentials, then tap Continue.
- Tap Finish.
If the Arlo Go 2 camera is installed too far from your Wi-Fi router, it may cause the battery to drain quicker. For more information, visit: How do I control whether my Go 2 Camera connects to Mobile or Wi-Fi?
