Arlo Go 2 LTE / WiFi Security Camera FAQs
Last updated: 08.01.2025
Arlo Go 2 Features
  • What’s the difference between Arlo Go and Arlo Go 2 Cameras?
    The redesigned Arlo Go 2 is loaded with new features like LTE and Wi-Fi connectivity, 1080p video resolution, color night vision, a spotlight, two-way audio, a siren, and GPS camera location.
  • Where can I use Go 2?
    Monitor nearly any location with a Wi-Fi or LTE connection. The camera is portable so you can take it with you and rely on a backup connection to the cellular network to ensure your cameras remain armed even when Wi-Fi is unavailable.
  • Is it better to connect to a Wi-Fi signal or wireless mobile signal on my Go 2?
    Go 2 is designed to be flexible. For example, you can use your Wi-Fi with cellular mode as a backup, so you’re always protected even if the Wi-Fi goes out. Or you can take your Go 2 to a remote location with no Wi-Fi and use LTE mode by itself. To learn more about both options, visit: What are the benefits of connecting my Go 2 Camera via mobile or Wi-Fi?
  • Do I need a SIM card for Arlo Go 2 mobile coverage?
    Yes. Your Arlo Go 2 camera requires an activated SIM card with a mobile data plan to access the mobile network. For help with your mobile service plan, contact the carrier of the SIM card that was provided. If no SIM card was included, visit your local wireless carrier to activate a service plan and receive a SIM card.
  • What options do I have if I do not have an activated SIM card?
    If you do not have an activated SIM card, you can set up the device Wi-Fi mode. To learn more, visit: What are the benefits of connecting my Go 2 Camera via mobile or Wi-Fi?
  • Does Arlo Go 2 come with an Arlo subscription?
    Some retailers sell Arlo Go 2 with a voucher for 24-months of Arlo Secure. This voucher will be included in the box.
  • What are the storage options for the Go 2?
    Use your Arlo Secure subscription to store videos in the cloud. Or install a microSD card (not included) to store your data locally.
Arlo Go 2 Mobile Providers
  • Which mobile service providers can I use with Arlo Go 2 in the EU and UK?
    Providers vary by country:
    • Vodafone: UK, Ireland, Spain, Italy, Germany, Portugal, Netherlands
    • EE and BT: UK
    • 3 Mobile: UK, Austria
    • Deutsche Telekom: Germany
    • Mobilcom Debitel: Germany
    • O2: Germany
    • Bouygues: France
    • Telenor: Sweden
    • Telia: Sweden
    • KPN: Netherlands
    • Swisscom: Switzerland
    • Elisa: Finland
    • BITĖ: Lithuania, Latvia
  • How much cellular data does Arlo Go 2 use?
    Data use varies based on your environment and mobile service provider. Data consumption should range from 700MB to 2GB on a monthly basis, depending on the number of motion triggers and length of recordings.
To monitor Arlo Go 2 cellular data usage, contact your wireless provider. For more information, visit:
Arlo Go 2 Installation
Arlo Go 2 Accessories and Partners
  • Which Arlo accessories are compatible with Arlo Go 2?
    • Outdoor Mounts
      VMA1000-10000S (white)
      VMA1000B-10000S (black)
    • Dual-Battery Charging Station
      VMA5400C-100xxS
    • Solar Panel Charger
      VMA5600-100S
    • Extra Rechargeable Battery
      VMA5420-10000S
    • Magnetic Indoor/Outdoor Charging Cable
      VMA5600C-100xxS (white)
      VMA5601C-100xxS (black)
    • Indoor Charging Adapter
      VMA5000C-100xxS (white)
      VMA5001C-100xxS (black)
    • Black Housing
      VMA3800H-100S
  • Which mobile service providers can I use with the Arlo Go 2?
Arlo Go 2 currently works with Verizon Wireless and T-Mobile.
  • How much cellular data does the Go 2 use?
To monitor Go 2 cellular data usage, contact your wireless provider. Learn more:
Go 2 Installation
  • Which Arlo accessories are compatible with the Arlo Go 2?
    • Outdoor Mounts
      VMA5400C-100xxS
      VMA5600-100S
      VMA5420-10000S
    • Black Housing
      VMA3800H-100S
