How accurate is geofencing?
For accuracy, geofencing uses a combination of GPS, cellular data, and WiFi data:
- In urban environments, where the cell towers and Wi-Fi routers are more dense, geofencing accuracy can reach 100-200 meters.
If you live in a skyscraper, geofencing might not work reliably due to GPS inaccuracies. Using the Large radius setting may help. - In more rural areas, where cell towers and WiFi routers are sparse, geofencing accuracy can reach several hundred meters.
To improve geofencing accuracy, ensure your mobile device meets these conditions:
- WiFi is turned on.
- GPS or location services are turned on.
