Note: After you complete the following steps, you cannot switch back to using SmartThings without performing the setup process again.
To stop using SmartThings and resume using the Arlo app, follow these high-level steps:
Each of these steps is explained in detail in the following sections.
To remove your Arlo cameras from the SmartThings mobile app:
To Remove the Arlo (Connect) SmartApp:
To delete the SmartThings mode and put your Arlo System in a different mode:
