How do I reset my Arlo Go camera to factory default settings?
If you reset your Arlo Go camera or remove it from your account, you forfeit all prepaid Arlo Mobile service for that monthly billing period. If you are using a different service provider, such as AT&T or Verizon, resetting your camera has no effect on your service provider account.
The easiest way to reset your Arlo Go camera is to remove it from your account.
If your Arlo Go camera is not in network coverage or is not connected to the cloud, you must scan a QR code to reset it.
To continue using your Arlo Go camera after you reset it, you must complete the new system setup process again.
To reset your Arlo Go camera while it is connected to the cloud:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
- Tap or click Settings > My Devices and select the Arlo Go camera that you want to reset.
- Tap or click Remove Device.
- Tap or click Yes to confirm that you want to remove the Arlo Go camera from your account.
You Arlo Go camera is reset to factory default settings. For more information about setting up your Arlo Go camera again, see How do I set up my Arlo Go camera?.
To reset your Arlo Go camera while it is not connected to the cloud:
- Press and release the sync button on the top of the camera
You hear a click. - Hold the camera about 4 to 8 inches (10 to 20 cm) in front of this QR code until you hear a chime:
Your Arlo Go camera is reset to factory default settings. For more information about setting up your Arlo Go camera again, see How do I set up my Arlo Go camera?.
