The magnetic mount is concave and fits perfectly with the shape of the rear of your camera. This allows a more precise fit between the mount and camera, and it enables dynamic ways to mount an Arlo Ultra and Arlo Pro series camera, including: walls, tabletops, and underneath ceilings. The strong magnetic force between these cameras and the mount provides peace of mind that the camera will stay in position.
To mount your Arlo camera:
You can replace the batteries on an Arlo Ultra and Pro series camera without removing your camera housing from the indoor wall mount.
Warning: When inserting the camera into the camera housing, do not push down on the lens or soft area below the lens.
To replace the batteries on an Arlo Ultra or Pro series without removing the camera from the wall mount:
For more information about mounting Arlo wire-free cameras, visit How do I mount my Arlo Wire-Free or Arlo Pro Wire-Free camera using the indoor wall mount?.
