Follow these instructions if your Arlo camera is currently set up and directly connected to a router, and you want to connect the camera to a VMB5000, VMB4540, VMB4500, or VMB4000 SmartHub or base station.
If your Arlo camera is not already set up, review the instructions on the in-package quick start guide.
Before you begin:
To connect your Arlo camera to your SmartHub or base station:
To switch your Arlo camera from a direct-to-WiFi connection to a SmartHub or base station, you must remove your Arlo camera from your account and re-onboard it. Exact steps are provided below.
