You can use the Arlo app and a compatible camera to have a remote conversation with someone who is standing next to your camera. If you want to speak to the person who approached the camera, tap the camera feed in the Arlo app, tap the microphone icon, and begin speaking.
Note: Your device must include or be connected to a working microphone for you to have a two-way conversation with your Arlo camera.
When using full-duplex 2-way audio, you only need to tap the microphone in the Arlo app to begin a conversation. You can talk and listen at the same time.
To use full-duplex 2-way audio:
A mute/unmute Microphone button displays below the camera feed.
Using push-to-talk is functionally identical to speaking through a walkie-talkie. You must press and hold the microphone button in the Arlo app to speak, then release it to listen to the audio from your Arlo camera.
To use push-to-talk:
