What should I do if the USB LED on my Arlo base station blinks amber?
If you press the Sync button on your Arlo base station for longer than a few seconds, the USB LED blinks amber and blocks the sync process.
Try these troubleshooting options if your USB LED blinks amber:
  • Do not touch your base station for 15 minutes. After 15 minutes, try resyncing your system.
  • Power cycle your base station by turning your base station off and then back on again.
