You can stream up to a theoretical maximum of 15 Arlo cameras at the same time, but this is dependent on your system set up and your Arlo Smart plan. Additionally, you might not be able to stream from all five cameras per SmartHub or base station if your WiFi network has limited bandwidth or if you are uploading other files while Arlo is streaming. For more information, visit What are the minimum requirements for installing and using my Arlo system?.
On the Arlo app for iOS or Android, you can stream simultaneously from a maximum of five Arlo cameras that are connected to a single SmartHub or base station. To start streaming a sixth camera, you must pause one of the active streams.
If your cameras are not connected to a SmartHub or base station, or if you have multiple SmartHubs or base stations, you can stream up to 15 cameras with an Arlo Smart Elite plan. For more information about Arlo Smart plans, visit What are the available Arlo subscription plans and how much cloud recording is available?.
On the Arlo web client, you can stream simultaneously from a maximum of five Arlo cameras that are connected to a single SmartHub or base station. To start streaming a sixth camera, you must pause one of the active streams. You can’t stream from more than five cameras simultaneously, even if you utilize multiple SmartHubs or base stations.
For more information about troubleshooting Arlo streaming problems, see Why can't I see Arlo video streams from a web browser?.
