Can I connect more than one Arlo or Arlo Pro base station to a network?
You can connect more than one Arlo or Arlo Pro base station to a network if open Ethernet ports are available on your router. Each base station must be connected to your router using an Ethernet cable.
Note: You can also connect an Arlo or Arlo Pro base station to a WiFi extender if the extender has an available Ethernet port.
