How do I insert the rechargeable battery into my Arlo Security Light?
Before you insert the rechargeable battery for the first time, we recommend that you follow the instructions in your Arlo app to set up your Arlo Security Light system.
To insert the rechargeable battery:
  1. Unlock the battery compartment cover by pressing and releasing the back of your Arlo Security Light.
  2. Align the battery contacts.
  3. Insert the battery all the way into the battery compartment.
    An image of an Arlo Security Light with the battery compartment cover removed and the battery lined up with the battery contacts, about to be inserted.
  4. Place the battery compartment cover back on your Arlo Security Light.
    You might need to hold the battery in place while you close the cover.
