How do I get better picture quality from my Arlo camera?
Improve the picture quality by maintaining the minimum upload requirement for your Arlo camera and use the Arlo Secure App to adjust the video settings.
Note: If you have a legacy Arlo camera (Arlo Wire-Free (VMC3030), Arlo Pro, Arlo Pro 2, Arlo Q, Arlo Q Plus, or Arlo Baby) that includes free cloud storage, the bit rate is reduced. If you purchase an Arlo service plan, the camera records in higher quality.
To improve picture quality:
- Check the upload speed requirement.
- Ensure that your upload speed meets the minimum requirements for each camera. Arlo cameras require between 1 to 3 Mbps upload bandwidth per camera.
- For more information, visit: What are the minimum requirements for installing and using an Arlo system?
- To check your internet speed, visit www.speedtest.net
- Change the Power Management setting to Best Video.
- For the Arlo Secure experience with Feed, visit: How do I change my Arlo camera Power Management settings?
- Note: If bandwidth is limited on your Wi-Fi network, selecting Best Video might not improve video quality. Both the upload speed and the connection between the camera and Wi-Fi router, Arlo SmartHub, or Arlo Base Station affects video quality.
- Choosing Best Video also may reduce battery life for wire-free cameras.
- Place your camera in a location with a good Wi-Fi signal.
- For more information, visit: Arlo Camera Placement Tips
- Minimize the number of networks, Wi-Fi devices, and transmitted frequencies near your camera and Wi-Fi router, Arlo SmartHub, and/or Arlo Base Station.
- To improve your connection, avoid uploading other data while you are streaming video.
- Simultaneous uploads might degrade the quality of your Arlo video stream.
- This includes uploading torrent files, uploading videos or pictures to remote websites such as Flickr or YouTube, or remote backup sites and cloud drives such as Dropbox or iCloud.
- If your router supports Quality of Service (QoS) or traffic shaping, make sure that your router settings are optimized for streaming video.
- For Arlo Pro 5S cameras, enable both 2.4GHz and 5GHz to get the best connectivity.
- For more information, visit: How does the Arlo Pro 5S Camera use 5GHz Wi-Fi networks?
