It's important to safely remove the SD card from your Arlo Go camera. If you remove an SD card while information is being recorded on it, the SD card might become permanently unusable or the files on the card might be corrupted.
If you remove the SD card that is connected to your Arlo Go camera, SD card recording is disabled until you insert another SD card.
To safely remove an SD card from your Arlo Go camera:
For more information about using an SD card for local backup storage on your Arlo Go camera, visit the following knowledge base articles:
