You can remove your Arlo Essential Video Doorbell (wired and wire-free configurations) from the wall mount without unscrewing anything or disconnecting any wires. To remove the doorbell from the wall, you need the release pin that came with your Arlo Essential Video Doorbell. You can also use a straightened paperclip or a similar object.
WARNING: Make sure that the power is turned off at the breaker if you plan to adjust the wiring on your Arlo Essential Video Doorbell.
To remove your Arlo Video Doorbell from the wall mount:
