How accurate is geofencing?
For accuracy, geofencing uses a combination of GPS, cellular data, and WiFi data:
  • In urban environments, where the cell towers and Wi-Fi routers are more dense, geofencing accuracy can reach 100-200 meters.
    If you live in a skyscraper, geofencing might not work reliably due to GPS inaccuracies. Using the Large radius setting may help.
  • In more rural areas, where cell towers and WiFi routers are sparse, geofencing accuracy can reach several hundred meters.
To improve geofencing accuracy, ensure your mobile device meets these conditions:
  • WiFi is turned on.
  • GPS or location services are turned on.
