How do I change the audio sensitivity on my Arlo camera?
To change the audio sensitivity on your Arlo camera:
  1. Launch the Arlo app or log in to your Arlo account at my.arlo.com.
  2. Tap or click Mode.
  3. Tap or click the camera whose audio sensitivity you want to change.
    If your Arlo camera is connected to an Arlo SmartHub or base station, tap or click the SmartHub or base station that is connected to the camera whose audio sensitivity you want to change.
  4. Tap or click the pencil icon next to the mode for which you want to change audio sensitivity.
  5. Tap or click the pencil icon next to the rule for the camera whose audio sensitivity you want to change.
  6. Tap or click the pencil icon next to the audio trigger.
  7. Adjust the sensitivity level for audio detection using the slider.
  8. Tap or click Save.
  9. Tap Edit Rule > Done.
Your audio sensitivity settings are saved.
