Heed all warnings in this document and warning labels attached to the camera, cords, and accessories. Failure to do so could result in injury.
STRANGULATION HAZARD – Children have STRANGLED in cords. Keep cord out of the reach of children (more than 3ft (0.9m) away).
NEVER place the camera or cord in or near crib or playpen. Secure the cord at least three feet away from crib or playpen.
NEVER mount the camera directly above crib or playpen to avoid the risk of injury.
NEVER use extension cords with AC adapters. Only use the AC adapters provided.
CHOKING HAZARD – This product contains small parts which may cause choking. Keep small parts away from children.
ELECTRIC SHOCK WARNING – Never use this device near water, including near a bathtub, sink, laundry tube, wet basement, etc.
This product and accompanying accessories are NOT toys. Do not allow children to play with them.
This product is NOT intended to replace proper supervision of children. You MUST check your child’s activity regularly.
This product is not intended for use as a medical camera and its use should not replace adult supervision.
Only a battery pack of the same type should be inserted by an authorized Arlo service center. There is a risk of explosion if the battery is replaced by an incorrect type.
Unplug product during lightning storms.
Recommended Safe Use
It is essential that you check the operating range and condition of the camera on initial installation, and on a regular basis after that
Check reception regularly. Test the camera before use and after changing camera location.
Some adult assembly or installation is required. Keep small parts away from children when assembling.
This product is intended for indoor use only.
Clean the camera with dry cloth only.
Do not block any ventilation openings.
Do not install near any heat sources such as radiators, heat registers, stoves, or other devices that produce heat.
Only use attachments and accessories specified by the manufacturer.
Only use with the stand, mount, and mounting screws specified by the manufacturer, or sold with the device.
Unplug this device when unused for long periods of time.
Do not touch the plug contacts with sharp or metal objects.
This product should only be serviced by authorized Arlo service centers. Contact Arlo Support at arlo.com/support for RMA information.
