Are Arlo cameras weatherproof?
Arlo Ultra, Pro 3, Pro 2, Pro, Wire-Free, Video Doorbell, Audio Doorbell, and Go are weather resistant and can be used indoors and outdoors. These devices work in a wide variety of weather conditions, including sun, wind, rain, and snow.
Arlo Q PlusQ, and Baby cameras are designed for indoor use only.
Arlo operating temperatures
  • Arlo Ultra and Pro 3: -4°F to 140°F (-20°C to 60°C)
  • Arlo Video Doorbell: -4° F to 113° F (-20° C to 45° C)
  • Arlo Pro 2: -4°F to 104°F (-20°C to 40°C)
  • Arlo Pro and Arlo Go: -4° F to 113° F (-20° C to 45° C)
  • Arlo Wire-Free: 14° F to 122° F (-10° C to 50° C)
Outdoor use guidelines
When you use your Arlo device outdoors, make sure to follow these guidelines:
  • Use an Outdoor Power Adapter if you plan to keep your camera plugged in while it is outside. The Arlo power adapter that came with your camera is not weatherproof.
  • Arlo Pro 2, Pro, and Go cameras can only be charged outdoors with the Arlo Solar Panel. Otherwise, Arlo cameras must be charged indoors.
  • Do not allow the Arlo camera’s power adapter, battery, or battery compartment to get wet.
  • Do not remove the rubber USB cover on your camera’s charging port.
  • Arlo Pro 2, Pro, and Go UV-resistant silicone skins (sold separately) provide additional protection against condensation and sun glare.
For important information about camera and battery safety, visit the following knowledge base articles:
