How do I create a new mode for my Arlo Q and Arlo Q Plus cameras?
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
- Tap or click Mode.
- Tap or click the device for which you want to create a new mode.
- Tap or click Add a Mode.
- Enter a name for the mode and tap or click Next.
The Trigger Device page displays.
- Tap or click a device and Next.
Note: If you have just one device, your device is preselected.
- Tap or click Next.
Note: If you want to create a mode that does not activate when motion or audio is detected, unselect the triggers.
- Set the motion sensitivity and the motion detection zones and tap or click Next.
Note: You can use the sliders to adjust the sensitivity of the motion sensor. To specify motion detection zones, tap or click Create Activity Zones.
- Set the audio sensitivity and tap or click Next.
- When prompted, specify what you want your device to do when motion or audio is detected and tap or click Next.
Note: You can select Record video, Take snapshot, or Do nothing.
- When prompted, specify how long you want your device to record for when motion or audio is detected and tap or click Next.
- Select the type of notifications that you want to receive and tap or click Next.
- If you selected Email Alerts, enter the email addresses that you want alerts to be sent to and tap or click Next.
The Summary page displays.
- Review your settings and tap or click Save.
Your new mode is saved.
