Arlo
Pro 3 Floodlight
Our most powerful floodlight camera
The first 100% wire-free floodlight camera illuminates the most vulnerable parts of your property. A motion-activated light more powerful than a car headlight deters intruders before they even get close to your property. While 2K video captures all the important details for the best possible protection.
6 month battery life1
Wire-free, no cords or wiring hassles
Superior Brightness
Up to 3000 lumens of light2
2K HDR
See clearer details and colors
Color Night Vision
See colors at night
Built-in Smart Siren
Trigger your siren remotely
Connect and control with your favourite smart assistant
Wire-Free Security
Installed in Minutes.
Easily mounts in multiple locations
for protection from every angle.
Powerful illumination where you need it most.
Light up your property with 2000-3000 lumens. Floodlight that’s more powerful than a car’s headlights.
Capture all the important details day or night.
Arlo Floodlight captures all the important details day or night
Color Night Vision
See video in full color or traditional black and white.
2K HDR
Zoom in on objects and capture clearer details and colors
160° Viewing Angle
Keep an eye on what matters with a wide 160° diagonal field of view.
Weather-resistant design
Built to withstand heat, cold, rain or sun.
Custom control to  easily adjust brightness, video and audio settings
Custom Control
Easily adjust brightness, video, and audio settings to your preference.
Go wire-free with a long-lasting battery
Rechargeable battery
Go wire-free with a convenient and long-lasting battery.
Keep your floodlight camera charged all day with multiple power options
Multiple power options
Keep your floodlight camera charged all day with an optional Solar Panel or Outdoor Charging Cable. 4
3-month Arlo Smart trial included
Personalized notifications keep you informed of events that matter so you can take quick action—from phoning a friend to sound an alarm, or calling emergency services.
Technical Specifications
Specifications
  • Max Video Resolution
    2560x1440 resolution
  • Image Sensor
    4 megapixels
  • Video Modes
    2K, 1080p, 720p
  • Video Features
    Auto Track and Zoom, HDR, H.264 and H.265 Encoding
  • Lens Field of View
    160 degree diagonal
  • Sensor Size
    1/3"
  • Light Type
    Floodlight
  • Light Color Temperature
    4000K
  • Efficacy/Brightness
    2000-3000* lumens (Outdoor Magnetic Charging Cable required for 3000 lumens)
  • Light Modes
    Constant and pulsate
  • Motion Detection
    Single Motion Detector, 130 degree horizontal
  • Siren
    Built-in
  • Night Vision - Color
    Yes
  • Night Vision - Black and White
    2 High Powered Infrared
  • AC Adapter Output
    5V 2A
  • AC Adapter Input
    100-240V AC, 50/60Hz
  • Indoor/Outdoor
    Both - outdoor UV and weather-resistant
  • Digital Zoom
    12x
  • Microphone
    Single Microphone with noise and echo cancellation
  • Audio
    Full Duplex 2 way Audio
  • Status Lights
    Dual colored LED
  • Networking
    802.11 b/g/n
  • Compliant Standards
    128-bit SSL, AES-128, TSL, 2 factor authentication
  • Battery Type
    Re-chargeable
  • Charge Time to Full (via camera)
    6.5 hrs
  • Charge time to Full (via charger accessory)
    5 hrs
  • Operating Temperature
    -20 to 45 degree Celsius
  • Connectivity
    Wi-Fi Connection. Working broadband connection with at least 2Mbps upload speed
  • USB requirements
    N/A
  • Minimum upload speed
    2-4Mbps
Certifications
  • Regulatory
    FCC, IC, CE, RCM compliant
Dimensions
  • Dimensions
    218.5mm x 190.5mm x 77.9mm
  • Weight with Battery
    650g
  • Wired/Wire-Free/Both
    Both
  • Requirements
    High-speed Internet Connection
Warranty
Shop Arlo Pro 3 Floodlight
  • Pro 3 Floodlight Camera
    (FB1001-100EUS (-100UKS))
  • Pro 3 Floodlight Camera - Black
    (FB1001B-100EUS (-100UKS))
Buy Now
What's included:
  • 1 Arlo Pro 3 Floodlight Camera
  • 1 XL Rechargeable Battery
  • 1 Power Adapter
  • 1 Micro-USB Cable
  • 1 Wall Plate and Screw Kit
  • 1 Quick Start Guide
  • 1 Video Monitoring Decal
Buy Now
What's included:
  • 1 Arlo Pro 3 Floodlight Camera - Black
  • 1 Power Adapter
  • 1 Micro-USB Cable
  1. Based on usage of 4000 seconds per month, 30 seconds per stream, and day/night event splits 2:1. Will vary with device settings, use, activity captured and environmental factors.
  2. Requires outdoor charging cable to emit up to 3,000 lumens.
  3. HomeKit compatibility for Pro 3 Floodlight requires connection to a compatible smart hub or base station. Visit here for Smart Hub/Base Station compatibility.
  4. All Pro 3 Floodlight Cameras include 3 months of service. Arlo Smart service not available in certain countries. See www.arlo.com/arlosmart for details.
  5. Renewal of an Arlo Smart subscription is required to maintain Arlo Smart features, including cloud storage.
  6. e911 feature available for U.S. subscribers only.
