How do I clear a 'Geofencing is enabled' notification on my Android device?
You can’t clear the ‘Geofencing is enabled’ notification on your Android device by swiping it or tapping Clear All. The notification must be cleared in your Android’s system settings.
To clear the ‘Geofencing is enabled’ notification:
  1. Swipe right on the notification until the gear icon appears.
  2. Tap the gear icon.
    The Settings page displays.
  3. Tap Minimize Notifications.
    The ‘Geofencing is enabled’ notification is removed.
To enable the ‘Geofencing is enabled’ notification:
  1. Navigate to your Android device’s system settings.
    For more information, visit the following Google support article: https://support.google.com/nexus/answer/6293419?hl=en.
  2. In the settings page, tap the Arlo app.
  3. Move the Show notifications slider to the right.
  4. Check the box next to Geofencing is enabled.
    The ‘Geofencing is enabled’ notification will appear in your device’s notifications.
