How do I mount my Arlo Q or Arlo Q Plus cameras?
To mount your Arlo Q or Arlo Q Plus camera:
  1. Remove the mounting plate from the camera base.
  2. Place the wall plate and secure it in the wall with four screws.
    Note: If you're mounting the camera to drywall, use the provided plastic anchors.
  1. Slide the camera into the wall plate.
    Note: Arlo Q and Arlo Q Plus cameras come with a magnetic plate that can attach to any flat steel or iron surface.
    Caution: Do not attempt to mount Arlo Q or Arlo Q Plus cameras to a half-dome Arlo Wire-Free camera mount. This might result in the camera falling from the mount and being damaged.
    For more information see the following YouTube video:
