Safety Instructions for Arlo Baby
Heed all warnings in this document and warning labels attached to the camera, cords, and accessories. Failure to do so could result in injury.
  • STRANGULATION HAZARD – Children have STRANGLED in cords. Keep cord out of the reach of children (more than 3ft (0.9m) away).
  • NEVER place the camera or cord in or near crib or playpen. Secure the cord at least three feet away from crib or playpen.
  • NEVER mount the camera directly above crib or playpen to avoid the risk of injury.
  • NEVER use extension cords with AC adapters. Only use the AC adapters provided.
  • CHOKING HAZARD – This product contains small parts which may cause choking. Keep small parts away from children.
  • ELECTRIC SHOCK WARNING – Never use this device near water, including near a bathtub, sink, laundry tube, wet basement, etc.
  • This product and accompanying accessories are NOT toys. Do not allow children to play with them.
  • This product is NOT intended to replace proper supervision of children. You MUST check your child’s activity regularly.
  • This product is not intended for use as a medical camera and its use should not replace adult supervision.
  • Only a battery pack of the same type should be inserted by an authorized Arlo service center. There is a risk of explosion if the battery is replaced by an incorrect type.
  • Unplug product during lightning storms.
Recommended Safe Use
  • It is essential that you check the operating range and condition of the camera on initial installation, and on a regular basis after that
  • Check reception regularly. Test the camera before use and after changing camera location.
  • Some adult assembly or installation is required. Keep small parts away from children when assembling.
  • This product is intended for indoor use only.
  • Clean the camera with dry cloth only.
  • Do not block any ventilation openings.
  • Do not install near any heat sources such as radiators, heat registers, stoves, or other devices that produce heat.
  • Only use attachments and accessories specified by the manufacturer.
  • Only use with the stand, mount, and mounting screws specified by the manufacturer, or sold with the device.
  • Unplug this device when unused for long periods of time.
  • Do not touch the plug contacts with sharp or metal objects.
  • This product should only be serviced by authorized Arlo service centers. Contact Arlo Support at arlo.com/support for RMA information.
