How can I see missed calls and listen to audio recordings from my Arlo Audio Doorbell?
If a visitor leaves an audio message after pressing your doorbell, the message is saved in your Arlo library.
To see a list of recordings and listen to a recording:
  1. Open the Arlo app or log in to your Arlo account at my.arlo.com.
  2. Tap or click Library.
  3. Tap or click an audio recording from the Arlo Doorbell.
    The Library page shows which device was triggered and how it was triggered.
    Note: The recording is classified as Missed in the library. You can filter your library recordings to show only the Missed type.
If you paired an Arlo camera to record on doorbell press, the missed audio recording also includes the video from the camera.
To filter through the Library and only see missed or accepted recordings:
  3. Tap or click Filter at the top left of the screen.
  4. Scroll to the bottom and tap or click Accept or Missed.
  5. Tap or click Done.
    The Arlo Library is filtered according to your preferences.
