How do I re-position my Arlo Pro 3 Floodlight Camera if it is already mounted?
You can adjust the angle of your Arlo Pro 3 Floodlight Camera after it has been mounted, without needing to unscrew or disassemble any mounting components.
To adjust the position of your Arlo Pro 3 Floodlight Camera without removing the mount:
  1. Use your fingers to loosen the grip on the mount.
  2. Adjust the angle of your Arlo Pro 3 Floodlight Camera.
  3. Launch the Arlo app.
  4. Select your Arlo Pro 3 Floodlight Camera.
  5. Tap Device Utilities > Camera Positioning.
  6. Confirm the placement of your camera by using the live stream in the Arlo app.
    Note: For your safety, consider asking a friend or family member to use the Arlo app while you adjust the angle of your camera.
  7. Use your fingers to tighten the grip on the mount.
