The Dusk to Dawn Sensor setting lets you customize when you want your Arlo Security Light to turn on when motion is detected based on the amount of ambient light.
To change the sensor setting:
Launch the Arlo app or log in to your Arlo account at my.arlo.com. The Devices page displays.
Tap or click Settings > My Devices.
Select the Arlo Security Light that you want to customize.
Tap or click Dusk to Dawn Sensor.
Move the slider to adjust the ambient light sensitivity level. Note: Move the slider toward Bright if you want Arlo Security Light to turn on when it is bright outside and motion is detected.
