How do I mount my Arlo Security Light?
To mount your security light:
  1. Use the provided screws to attach the mount to the wall.
    An image showing the Arlo Security Light mount positioned against a while with horizontal lines showing where the screws go.
  2. Tighten the metal collar on the mount to secure the post.
  3. Screw the light onto the threaded post.
  4. Tighten the plastic collar to secure the light.
    An image showing where the Arlo Security Light screws onto the mount, in the back rear of the light.
  5. Tilt and swivel the light to your preferred position.
    An image showing how the Arlo Security Light can tilt or swivel on the mount
