You can’t clear the ‘Geofencing is enabled’ notification on your Android device by swiping it or tapping Clear All. The notification must be cleared in your Android’s system settings.
To clear the ‘Geofencing is enabled’ notification:
To enable the ‘Geofencing is enabled’ notification:
