How can I connect my Arlo Baby camera to a different WiFi network?
After you connect your Arlo Baby camera to a different WiFi network, you must re-enable your camera before you can stream video from the camera. The camera is disabled as a security measure whenever Arlo detects a network change.
To connect your Arlo Baby camera to a different WiFi network:
  1. Launch the Arlo app or log in to your Arlo account at my.arlo.com.
    The Devices page displays.
  2. Tap or click Settings > My Devices.
    A list of cameras displays.
  3. Tap or click Arlo Baby to select it.
  4. Tap or click Device Settings.
  5. Tap or click Wi-Fi Network.
    The name of your currently connected WiFi network displays.
  6. Enter the new WiFi network name and password.
  7. Tap or click Continue.
  8. Follow the prompts to connect your Arlo Baby camera to the new WiFi network.
    If you are using a mobile device, your settings are saved.
  9. If you are using a computer, click Save.
    Your settings are saved.
  10. If you see the Renable Camera button on your Devices page, press and hold the Sync button on your Arlo Baby camera for 10 seconds.
  11. Wait two minutes.
    You are able to stream from Arlo Baby again. If you do not want to wait two minutes, you can power cycle your Arlo Baby camera instead.
For more information about power cycling Arlo Baby, see How do I power cycle my Arlo Baby camera?.
