With Apple HomeKit and a compatible Arlo device, you can use voice commands to access and control multiple Arlo cameras from one place. To take full advantage of these features, you need a supported and connected Arlo system. For more information, visit What are the benefits of connecting my Arlo camera to Apple HomeKit?.
You can also connect an Arlo Baby camera with the Apple Home app. For more information, visit How do I set up a new Arlo Baby camera with HomeKit?.
You must be on the same WiFi network as your Arlo SmartHub or base station when you first connect Arlo to HomeKit. After your Arlo device is added to HomeKit, you must have an Apple home hub to access your Arlo devices on HomeKit when outside your local network. For more information, visit the following Apple support article: https://support.apple.com/en-us/HT207057.
You need the following to use Arlo with Apple HomeKit:
To find your base station’s firmware version, visit How do I find the serial number and firmware version of my Arlo device?.
You can connect your Arlo camera to the Apple Home app in two ways:
To set up an Arlo camera with a setup code:
To setup an Arlo camera without a setup code:
