How do I keep my Arlo batteries charged in cold weather?
Last updated: 08.01.2025
Arlo camera batteries might report low power in cold weather due to slower internal chemical reactions at low air temperatures.
Arlo Ultra series cameras, Arlo Pro series cameras, Arlo Go series cameras, Arlo Essential wire-free cameras, and the Arlo Essential Video Doorbell Wire-Free all have a minimum operating temperature of -4°F (-20°C).
The original Arlo Wire-Free Camera (VMC3030) has a minimum operating temperature of 14°F (-10°C).
The Arlo Solar Panel has a minimum operating temperature of 32°F (0°C).
Note: For your safety and to avoid permanent damage, Arlo batteries do not charge at temperatures below freezing, even if your camera is plugged into AC power or using an Arlo Solar Panel.
Follow these tips to keep your batteries charged in cold weather:
- If your camera stops charging because the battery is too cold, bring the camera to a location where the temperature is above freezing and plug it in.
- Your camera resumes charging as soon as the battery reaches a safe temperature.
- If your cameras are in a location that routinely experiences temperatures below freezing, you might need to bring your cameras inside to charge more frequently than in warmer months.
- You can also use an Arlo Dual Charging Station to keep spare batteries charged for your Arlo Ultra series, Arlo Pro series, or Arlo Go series cameras.
- The Arlo Solar Panel might not be able to keep your camera fully charged on days that are cloudy, rainy, or otherwise don’t provide enough solar energy.
- The Arlo Solar Panel might be unable to keep your camera charged during periods of heavy use.
- The total energy that an Arlo Solar Panel can produce depends on external factors such as temperature, shade, weather, and the amount of dust or debris on its surface.
- If the Arlo Solar Panel is not keeping your battery charged, clean off any accumulated dust or debris and ensure it is receiving enough sunlight.
If your camera battery level drops suddenly in cold weather:
- Return the camera to room temperature and power cycle the camera by removing and reinstalling the batteries without the camera plugged in.
After the camera is back online, check if the battery capacity notification is restored to normal. - If your camera is still reporting low battery in cold weather, place your camera in a warmer location to see if the problem is duplicated in that setting.
- If you still have problems with your battery power, visit Arlo Support to speak with an expert.
For more information about the Arlo Solar Panel, visit:
For more information about battery icons, battery notifications, and battery life, visit:
- What do the Arlo camera battery level icons and notifications mean?
- How can I extend Arlo camera battery life?
For more information about Arlo Wire-Free Camera (VMC3030) batteries, visit:
