What do the Arlo camera battery level icons and notifications mean?
Last updated: 08.01.2025
You will receive a low battery notification when Arlo camera battery charge drops to 15%.
Temperature variations can affect the accuracy of the displayed camera battery level in the Arlo Secure App. Battery levels are most accurate between 65-75°F (18-24°C).
Camera battery level is less accurate when frequently streaming the camera or operating it in cold or hot weather conditions.
To view your Arlo camera battery level:
  1. Launch the Arlo Secure App.
  2. Tap Devices.
    The Arlo camera battery level displays on the bottom of the device card. Battery level is also displayed on the Device Settings screen.
    Note: If your Arlo camera is offline, the battery icon is hidden.
The following represents the remaining battery level based on the battery icon shown in the Arlo Secure App:
Battery Icon
Battery Level
Full battery
76%-100%
Mostly full battery
51%-75%
Half-full battery
26%-50%
Low battery
1%-25%
Dead battery
0%
If your battery-powered camera is plugged in, the following icons display instead:
Battery Icon
Meaning
Battery Full
(Plugged in)
Battery Charging
(Plugged in)
Battery Not Charging
(Plugged in but not charging due to temporary condition, such as low light on solar panel or temperatures too cold for charging)
If the charging disabled icon Charging disabled is displayed, the battery is too hot or too cold to charge safely. Batteries cannot charge safely in temperatures below 32°F (0°C) or above 113°F (45°C). Arlo cameras can still function in temperatures below freezing, but charging is disabled for safety reasons. Bring your camera indoors and allow it to reach a safe temperature before attempting to charge again.
The charging disabled icon can also mean an incompatible charging cable is connected to your Arlo camera. You must use the power adapter and charging cable that came with your Arlo camera.
Note: Video Doorbells that are hardwired will not show a charging icon. Trickle charging starts when the battery level is less than 65% and stops at 80%.
If an Arlo Solar Panel is used, the following icons display:
Solar Icon
Battery Icon
Meaning
Battery Fully Charged
(It is possible that these icons will only display for a few minutes and then revert to gray)
Battery Charging
(If the battery is too cold or too hot, the battery will not charge)
No Icon
Battery or Charger Status Unavailable
If the Arlo Solar Panel is not keeping your Arlo camera charged, visit: How to troubleshoot Arlo Solar Panel charging issues
