Using advanced algorithms, your Arlo cameras alert you when a person is detected and filters out everyday movement, such as tree branches. This feature ensures that you see what is important and reduces unwanted alerts. The Person Detection feature also allows you to search the Arlo Feed for videos containing people. To use Person Detection, you need an Arlo subscription plan. For more information, visit: What Arlo subscription plans and cloud recording options are available?
To enable Person Detection:
- Launch the Arlo Secure App.
- Tap
- Select a Location with an Arlo Secure plan under Locations and Plans.
- Tap Smart Notifications.
- Select a camera under Active Cameras.
Note: If there is not a camera listed in the Active Cameras section, tap Edit and move the camera by tapping the three bars to the right of the camera name and hold while dragging it up from Inactive Cameras and dropping it into Active Cameras. Tap Save. - Tap the People switch to the on position to enable Person Detection for your Arlo camera.
For more information, visit: What are Arlo Smart Notifications and how do I set them up?
