How do I train Arlo Custom Detection?
Last updated: 17.06.2025
The Custom Detection feature allows you create your own unique detection scenarios.
Train your camera by using at least five snapshots of the scenario you want to detect. The more snapshots of the scenario, the better your Custom Detection works. Arlo also suggests that you train your Arlo camera with Night Vision snapshots to improve night performance of your Custom Detection.
Custom Detection training only applies to your account and is not shared with other Arlo accounts. For more information, visit: Arlo Custom Detection and Privacy
- Note: A Arlo Secure Plus plan is required for Custom Detection.
- To set up Custom Detection, visit: What is Arlo Custom Detection and how do I set it up?
To train Arlo Custom Detection:
Using Test Detection
- Launch the Arlo Secure App.
- Tap
- Select a Location with a Plus or Premium plan.
- Tap Custom Detection.
- Select a Custom Detection scenario that has been saved.
- Tap Test Detection.
- Tap Open, Closed, On, Off, or Unusable depending on the scenario.
From the Feed event of your existing Custom Detection:
- Tap Feed.
- Select the snapshot that you want to use to train your existing Custom Detection.
- Tap Verify this Detection.
From Push Notifications:
- Tap the Push Notification that you have received.
- Once you are on the Feed screen in the Arlo Secure App, select the snapshot.
