Select Country and Language
You can use the following verification methods:
1. Arlo account email address
Make sure that you have access to the email box associated with you Arlo Account. Your account email is always used as a backup option to log in to your account.
If you didn’t receive an email with a verification code, do the following:
2. Push notification
If you want to authorize a new device by using the push notification verification, you must be logged in to your Arlo account on the trusted device. If you didn’t receive a Push notification to verify a login, follow these steps:
3. SMS message
If you didn´t receive the SMS text message with a verification code, do the following:
Helpful article: How do I edit two-step verification settings?
4. Trusted browser
When you log in to your Arlo Secure account through a web browser, you will have the option to trust the web browser and keep it authenticated for up to 14 days, or until the browser´s cookies are cleared.
Helpful article: What is a trusted browser?
We recommend that you set up multiple different verification methods so that you’re covered if you lose access to one of them.
If you can’t access your trusted device to complete the log in, you can tap Try Another Verification Method. This allows you to send an SMS text message or email with a verification code to one of your approved phone numbers or email addresses.
Helpful articles: Why isn't two-step verification working?
What is two-step verification and how do I set it up with Arlo?
1. To add or remove trusted devices
To remove a trusted device, please launch the Arlo Secure App or log in to my.arlo.com and click Settings > Profile > Login Settings > Two-Step-Verification > Edit > trashcan icon.
You can also add a new method by clicking Add Trusted Device at the bottom of the screen.
Helpful articles: How do I edit two-step verification settings?
Why does the Arlo Secure app say it doesn’t recognize this device when I try to log in?
2. Trusted browser
If you’re not able to trust a browser, try the following:
Helpful article:
