Use the SmartThings App to remove Arlo and then resume using your Arlo devices with the Arlo Secure App.
To remove Arlo from the SmartThings App:
- Launch the SmartThings App.
- Tap Menu.
- Tap the Settings (gear) icon.
- Tap Linked services.
- Tap Arlo.
- Scroll down to the bottom of the screen and tap DELETE.
- Tap OK.
You will need to set up Arlo in the SmartThings App again if you want to use it in the future.
