How do I change the motion sensitivity for my Arlo Security Light?
To change the sensitivity level for a light:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
The Devices page displays. - Tap or click Mode.
- Tap or click the bridge that is connected to the light for which you want to change motion sensitivity.
The Mode page displays. - Tap the pencil icon or click Edit next to the mode.
The Edit Rule page displays. - Tap or click Edit next to the rule that you want to edit.
The Edit page displays. - Under If the following, tap or click Edit next to Motion is detected.
The Motion detection settings page displays. - Move the slider to adjust the sensitivity level for motion detection for this light.
If you used a mobile device to specify the settings, your settings are saved. - If you used a browser to specify the settings, click Save.
Your settings are saved.
