How do I connect my Arlo Q camera to a hidden Wi-Fi network?
You can connect your Arlo Q camera to a hidden wireless (WiFi) network (one that does not broadcast its SSID).
To connect your Arlo Q camera to a hidden network:
You need to know the name (SSID) of the hidden network. If you don't know the SSID, access your router's user interface to determine the SSID.
  1. During the Arlo Q setup process, enter the hidden Network Name (SSID), then enter the password for that network.
  2. Click or tap Submit to continue syncing the camera.
  3. Follow the onscreen instructions.
